Hand Throttle
   / Hand Throttle #1
jimmyb1
CECIL, OHIO
FORD 3400, YR. 1974 GAS
My hand throttle won't stay in place when over half way up it always
jumps back under 1/2 throttle is there some thing I need to adjust or
replace?
Thanks Jim
   / Hand Throttle #2
The model would be of great help.
Vintage Fords have a friction disc on the throttle that can be snugged up, or replaced if worn out.
   / Hand Throttle #3
ditto that.. we need to know what ford you have to give you specific advise.
throttle on the 9n/2n was different thant he 8n, and then from the naa thru the early 000 series.. etc.
soundguy
   / Hand Throttle
My tractor is a 1947 8N, hope this helps Soundguy an Jbrink64 let me know if you need more info. That would be sweet if all I had to do was tightin some thing up.
Thanks Jim
   / Hand Throttle #5
the 8n uses a ridged quadrant plate on the dash and an arm with a steel bearing ball crimped into the bar that runs across the quadrant.
it usually gets a flat spot onit. cheap fix is to spread bar with a screwdriver, rotate ball to a round spot and recrimp. if a groove is worn into the dash plate.. weld up and grind to fit.. or replace.
also there is a tension spring at the base of the hand throttle rod.
soundguy
   / Hand Throttle #6
soundguy
Ditto that. Also make sure the tension spring isn't rusted to the throttle rod-it needs to pull the throttle lever down against the quadrant.
   / Hand Throttle
Thanks Guys will work on it today.
Jim
TAKEUCHI TB235-2 EXCAVATOR (A52706)
TAKEUCHI TB235-2...
48 PIECE HEAVYEQUIPMENT KEY SETS (A53843)
48 PIECE...
2022 Toro Workman 07921 Electric Utility Cart (A51694)
2022 Toro Workman...
Lawnmower Deck (A53117)
Lawnmower Deck...
2019 Kenworth T880 T/A Wet Kit Day Cab Truck Tractor (A51692)
2019 Kenworth T880...
KUBOTA M5660 SU TRACTOR (A52706)
KUBOTA M5660 SU...
