Hand Throttle
   / Hand Throttle #1
jimmyb1
CECIL, OHIO
FORD 3400, YR. 1974 GAS
My hand throttle won't stay in place when over half way up it always
jumps back under 1/2 throttle is there some thing I need to adjust or
replace?
Thanks Jim
   / Hand Throttle #2
The model would be of great help.
Vintage Fords have a friction disc on the throttle that can be snugged up, or replaced if worn out.
   / Hand Throttle #3
ditto that.. we need to know what ford you have to give you specific advise.
throttle on the 9n/2n was different thant he 8n, and then from the naa thru the early 000 series.. etc.
soundguy
   / Hand Throttle
My tractor is a 1947 8N, hope this helps Soundguy an Jbrink64 let me know if you need more info. That would be sweet if all I had to do was tightin some thing up.
Thanks Jim
   / Hand Throttle #5
the 8n uses a ridged quadrant plate on the dash and an arm with a steel bearing ball crimped into the bar that runs across the quadrant.
it usually gets a flat spot onit. cheap fix is to spread bar with a screwdriver, rotate ball to a round spot and recrimp. if a groove is worn into the dash plate.. weld up and grind to fit.. or replace.
also there is a tension spring at the base of the hand throttle rod.
soundguy
   / Hand Throttle #6
soundguy
Ditto that. Also make sure the tension spring isn't rusted to the throttle rod-it needs to pull the throttle lever down against the quadrant.
   / Hand Throttle
Thanks Guys will work on it today.
Jim
2025 Wolverine EX-66-84L Pallet Fork Extensions (A53117)
2025 Wolverine...
2015 PCI MFG. SOLUTIONS 130 BBL STEEL VACUUM TRAILER (A53843)
2015 PCI MFG...
2022 BOBCAT T770 SKID STEER (A52705)
2022 BOBCAT T770...
2019 VOLVO TRUCK VNL (A53843)
2019 VOLVO TRUCK...
RV Hitch (A50121)
RV Hitch (A50121)
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
