Hand throttle for 2016 RTV X1140? I can't find one....Is it a unicorn?
   / Hand throttle for 2016 RTV X1140? I can't find one....Is it a unicorn? #141
The reason I installed the kit on my 1120 was to have increased pulling power, or at least it seems that way. With the kit installed you bring the engine speed up to whatever you want and the floor pedal then acts like the hydro pedal on your HST. If you hook something you need to pull with your tractor you don’t start out with engine at idle speed. Also if your setting for extended times and need to idle the engine you can raise the idle speed to allow for increased cooling and charging. They were originally needed for front mounted hydraulic brooms so max hydraulic flow could be maintained while in operation.
2015 DRAGON 130 BBL STEEL VACUUM TRAILER (A58214)
2015 DRAGON 130...
2017 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A58017)
2017 FREIGHTLINER...
2020 MACK P164T (A58214)
2020 MACK P164T...
Commercial Lawn Mower 652R (A56859)
Commercial Lawn...
2019 Toro Z Master 3000 Series 52in Zero Turn Commercial Mower (A56857)
2019 Toro Z Master...
2008 BMW 535xi AWD Sedan (A56859)
2008 BMW 535xi AWD...
