Hand throttle for 2016 RTV X1140? I can't find one....Is it a unicorn?
   / Hand throttle for 2016 RTV X1140? I can't find one....Is it a unicorn?
I'm an idiot. That's shift linkage.
   / Hand throttle for 2016 RTV X1140? I can't find one....Is it a unicorn? #12
The cable in your pic looks awful big to be throttle?? Are we sure it isn't buried deeper in there somewhere?? :(
   / Hand throttle for 2016 RTV X1140? I can't find one....Is it a unicorn? #14
   / Hand throttle for 2016 RTV X1140? I can't find one....Is it a unicorn? #15
Hard to say. Are a fabricator (cobbler)? The principle is going to be the same. You may have to rig up some bracketry at the injection pump as well as a method to hook up the cable end. In my setup when I use the foot pedal the hand throttle cable just falls slack, nothing high tech about it at all.
We were posting at the same time.... :)
I look at your pictures on my computer. My old eyes don't zoom enough on this phone.
(Thinking out loud) I wonder why the kit is offered for the 1140?
Thank you again for posting.
   / Hand throttle for 2016 RTV X1140? I can't find one....Is it a unicorn? #17
What surprises is me is that you've read in the manual about the hand throttle but can't find one.
Is your throttle a simple lever on the injection pump that your foot pedal cable moves?
If so, the "cobbling" I talked about above might apply.
I may buy the kit and try some fab'in later. I'm so busy right now with the warm weather coming I was really hoping for a bolt on kit.
Maybe the pages in my owners manual are generic RTV pages. 1519233353631.jpg
   / Hand throttle for 2016 RTV X1140? I can't find one....Is it a unicorn? #19
Looks like there is space on the throttle lever on the engine to add a second clevis for the added cable.
You need to see if you can add a bracket for the cable end to mount on, a intermediate support for routing the cable so it does not, rub, move or come in contact with the exhaust or moving parts and not kinked or too tight of turn, and a place to mount knob and base that is easy to get to and not in the way.
The hand throttle on earlier models was mounted near the hydraulic lever for dumping the bed, you may see if there is a plastic plug filling a hole already there.
On my RTV-1100, I was having problems with water in the fuel, and wanted to add a water separator and was just going to try and mount the filter from a B series tractor when I found out that they made a kit for the RTV-900. Got the kit and crawled under the RTV-1100 and found that the frame rails were already drilled and tapped for the kit and the filter guard and the only difference was the lengths of fuel and vent lines used and was able to use the kit with modifications.
So there are undocumented features that are engineered into the design that marketing department does not know about.
David
   / Hand throttle for 2016 RTV X1140? I can't find one....Is it a unicorn? #20
Kubota is real good about using parts such as frames for multiple applications.
He already has the spot for the knob so he's good there. :)
Toro 04358 Turf Reel Mower (A57149)
Toro 04358 Turf...
2011 JACK COUNTY TANK 130 BBL STEEL (A58214)
2011 JACK COUNTY...
CFG Industry MX15RX Mini Excavator (A57149)
CFG Industry...
Kubota HB84 Hopper Broom (A53317)
Kubota HB84 Hopper...
2010 JOHN DEERE 310J BACKHOE (A52709)
2010 JOHN DEERE...
2018 Ford Transit 350 (A57148)
2018 Ford Transit...
