Hand and foot throttle problem
   / Hand and foot throttle problem #1
remurden
Chesapeake, VA
Yanmar 1610D
Need some help with that looks like to be a simple setup. I have a YM1610d. I can use the hand throttle and pull back to increase speed but when i push back on the hand throttle to decrease speed the foot throttle does not come up and the hand throttle just has free play. I have to stick my foot under the foot throttle and pry it up to decrease speed. Any thoughts on how and what i need to get these two throttles working together?
Thanks,
Richard
   / Hand and foot throttle problem #2
Take a look at the linkages, sounds like something is binding up. Probably nothing more than bending a linkage straigth with a pair of pliers and some WD-40.
   / Hand and foot throttle problem #3
Dieselfuelonly has it right
Its lubrication where the throttle handle comes out the side, lube the 2 friction discs and the linkage between the two.
Also the foot throttle cable.
These are an easy fix with a can of spray.
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A53473)
Mitsubishi FG35...
2012 Honda Pilot SUV (A51694)
2012 Honda Pilot...
KUBOTA M7-132 LOT NUMBER 31 (A53084)
KUBOTA M7-132 LOT...
Polaris Side by Side (A50324)
Polaris Side by...
