Hammer drill recommendations?
/ Hammer drill recommendations? #21
After two Hilti's, I know they are very good quality. The SDS bits are the only way to go. I would agree with your contractor. I have found the Bosch to be a perfectly acceptable replacement for the Hilti. I was at Home Depot and saw all the Hilti's being sold there. The hammer drills are tops but get a load of the Sawzalls, talk about a retro saw. /forums/images/graemlins/grin.gif
/ Hammer drill recommendations? #22
</font><font color="blue" class="small">( If it was me given how much use you will have with it, I would go with a Harbor Freight unit, for $40 or even the $25 unit.
I agree I have one (the 25.00). Drilled concrete floor and a slab for tapcon screws. worked great. Should last a long time if your not a contractor and use it everyday, even then it should last a while, it is built pretty good.
/ Hammer drill recommendations? #24
Hit the quote button, copy what you want to quote, put the cursor in between the quote brackets and then paste. You can also copy before you hit the quote feature. Drop the cursor down a line and add your reply.
Sometimes the last "{quote}" will jump down a line, you can backspace it where it needs to be. I couldn't use the actual "[" or it would have activated the feature.
edit: if you preview your posts you will know if you did it correctly
/ Hammer drill recommendations? #25
if it were me i would use a powder nail driver to fasten the plate to the floor along with a treated lumber construction adhesive , this should more than be adequate to hold the wal in place unless ofcourse your driving a car or truck into the wall for some unknown reason. once the adhesive cures its holding things steadfast and if the nails do react to the newer chemicals in treated lumber well they did their job in a few days time so if they corrode and dissapear after the curing process so what , and as far as securing to block 20 fasteners wouldnt be a strecth for cordless drills in the 24 volt range / bosch but you be better of renting if this is as much drilling as you plan on . just my two cents worth and good luck
/ Hammer drill recommendations? #26
I read your post again and you said "My first preference is to get a high quality unit. My second preference is to get one that somehow supports a US worker moreso than a foreign worker. My third preference is to try to stay away from made in China"
To my knowledge, only Makita and Dewalt cordless tools are made in the US. Porter Cable and Milwaukee are made in China as I recall. I also seem to recall that only Makita and Dewalt sell replaceable brushes on their cordless tools.
/ Hammer drill recommendations? #27
Get a good corded 1/2 in hammer drill and dont look back. If you were making a living at it then Hilti is the only way to go. If I was going to give it a steady diet of 1/2 inch holes or better going deeper than 6 inches, I would spend big and go Hilti. You have light contracting/homeowner use. I have bored all kinds of holes with a 1/2 in Milwaukee hammer drill at work and at home. A Dewalt, Milwaukee, or something in that area will do it with regular masonery bits.
/ Hammer drill recommendations? #28
If you can a wait a little bit look into the new V28 fom Milwaulkee
/ Hammer drill recommendations? #29
Milwaulkee is now owned by a Hong Kong company the same one that owns Ryobi and Homelite
/ Hammer drill recommendations? #30
You know all those group mailboxes you see around? A friend of mine installed those on contract with USPS for years. He used two Hilti's.
I helped him with that stuff for a while. His Hilti broke... So he got one of the Bosch from Home Depot. That Bosch last 2 weeks, and was trashed. The Hilti was about 5 years old. We'd put op 25-35 boxes a day, requiring four 1/2 holes each.
The Bosch was a throw away. He had the Hilti repaired, and used it a lot till he moved to other work. Still uses the Hilti here and there. There are 4 or 5 bosches in the trash. That Bosch probably would have been ok for lighter duty use. The Bosch did work nice till it broke...
2016 Chevrolet Tahoe SUV (A60352)
2016 Chevrolet...
2008 GMC Savana 2500 Cargo Van (A59230)
2008 GMC Savana...
2023 Deere 325G (A60462)
2023 Deere 325G...
iDrive TDS-2010H...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2016 Ford F-150...
2005 Wacker Neuson PDT3A Portable Diaphragm Pump (A59228)
2005 Wacker Neuson...
