Had to replace a seal on loader cylinder - Re- install instructions
   / Had to replace a seal on loader cylinder - Re- install instructions #1
Atchuuu
Kubota L4330 HSTC
Hi Guys,
As the title says, I had a seal go bad on the loader lift. Probably from back dragging the bucket.
Anyways, lost a fair amount of hydro fluid. Took off cylinder and dropped it off at the shop today.
Can you tell me what I need to do once I get it back from the shop and re installed? Do I have to bleed out the air? Anything I should watch out for.
Thanks,
   / Had to replace a seal on loader cylinder - Re- install instructions #2
Just reinstall the cylinder and cycle the loader a few times. Then top off the hydraulic tank.
Thanks for the reply. I assume doing as you suggested will allow the air out of the system?
   / Had to replace a seal on loader cylinder - Re- install instructions #4
Yes it will take the air out.
Assemble everything back into place, start the tractor and move the lever till you see movement on the cylinder. It can take a few seconds to react since it has to fill the cylinder. Then you cycle it back and forward a couple times.
CASE CX57C EXCAVATOR (A52707)
CASE CX57C...
2017 Makita HM1307CB 35lb Demolition Hammer (A55973)
2017 Makita...
2010 Honda Accord Sedan (A55853)
2010 Honda Accord...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A55745)
2010 MAXEY WELDING...
2015 Ford F750 Reel Loader Truck (A52377)
2015 Ford F750...
UNUSED FUTURE 14' WROUGHT IRON BI-PARTING GATE (A57193)
UNUSED FUTURE 14'...
