Had to replace a seal on loader cylinder - Re- install instructions
   / Had to replace a seal on loader cylinder - Re- install instructions #1
Atchuuu
Kubota L4330 HSTC
Hi Guys,
As the title says, I had a seal go bad on the loader lift. Probably from back dragging the bucket.
Anyways, lost a fair amount of hydro fluid. Took off cylinder and dropped it off at the shop today.
Can you tell me what I need to do once I get it back from the shop and re installed? Do I have to bleed out the air? Anything I should watch out for.
Thanks,
   / Had to replace a seal on loader cylinder - Re- install instructions #2
Just reinstall the cylinder and cycle the loader a few times. Then top off the hydraulic tank.
Thanks for the reply. I assume doing as you suggested will allow the air out of the system?
   / Had to replace a seal on loader cylinder - Re- install instructions #4
Yes it will take the air out.
Assemble everything back into place, start the tractor and move the lever till you see movement on the cylinder. It can take a few seconds to react since it has to fill the cylinder. Then you cycle it back and forward a couple times.
Pallet of 3' LED Lights (A56469)
Pallet of 3' LED...
2019 Ford Escape S SUV (A55853)
2019 Ford Escape S...
SIDE PANELS FOR KUBOTA KX033-4 (A57192)
SIDE PANELS FOR...
2007 Godwin Pumps GHP45KW-RC 45kW Towable Diesel Generator (A53421)
2007 Godwin Pumps...
2015 Ford Taurus AWD Sedan (A55853)
2015 Ford Taurus...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
