Had to replace a seal on loader cylinder - Re- install instructions
   / Had to replace a seal on loader cylinder - Re- install instructions #1
Atchuuu
Kubota L4330 HSTC
Hi Guys,
As the title says, I had a seal go bad on the loader lift. Probably from back dragging the bucket.
Anyways, lost a fair amount of hydro fluid. Took off cylinder and dropped it off at the shop today.
Can you tell me what I need to do once I get it back from the shop and re installed? Do I have to bleed out the air? Anything I should watch out for.
Thanks,
   / Had to replace a seal on loader cylinder - Re- install instructions #2
Just reinstall the cylinder and cycle the loader a few times. Then top off the hydraulic tank.
Thanks for the reply. I assume doing as you suggested will allow the air out of the system?
   / Had to replace a seal on loader cylinder - Re- install instructions #4
Yes it will take the air out.
Assemble everything back into place, start the tractor and move the lever till you see movement on the cylinder. It can take a few seconds to react since it has to fill the cylinder. Then you cycle it back and forward a couple times.
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
2008 ELGIN SWEEPER (A52472)
2008 ELGIN SWEEPER...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2017 FREIGHTLINER...
