Hack welder now an aspiring hack machinist
   / Hack welder now an aspiring hack machinist #1
rankrank1
Platinum Member
SW OH - near Dayton, OH
1978 Kubota L285, 1951 Farmall h, 1946 Farmall m, 1950 John Deere A, 1953 Ford NAA Golden Jubilee, 195? Ford 850, 1948 Case DC, 1948 Case SC
Picked up a "new to me" toy a few weeks ago.
Fray model # 10RH vertical and horizontal mill combo. Hopefully, it will be an oldie but goodie. Always wanted a mill and this one came along in my budget. Maybe someday I will have as many toys (oh I mean tools) as Shieldarc.
   / Hack welder now an aspiring hack machinist #3
X and Y movement on both the table and head, tilt the head, swing the head, plenty of Z movement, probably limited RPM range, interesting. Make sure your gibs are adjusted, get some tool and work holders and you should be ready.
   / Hack welder now an aspiring hack machinist #4
That is a very interesting machine, I've never seen one quite like it.
   / Hack welder now an aspiring hack machinist #5
Guess it makes a narrow table act like a wide one. Make adding a DRO more of a trick.
   / Hack welder now an aspiring hack machinist #6
go check out keith fenners videos on youtube. He uses an old KT mill and he knows how to do all sorts of things with that old machine.
   / Hack welder now an aspiring hack machinist #7
When you get tired of it just let me know.:D looks like a great find.
   / Hack welder now an aspiring hack machinist #8
Trouble with most of the old stuff is that it takes 3 phase power... not a problem if you have it, but if you don't, then you have to buy or build single phase to three phase. A coworker years ago made a good size converter and had a shop full of 3 phase tools he got on the cheap.
   / Hack welder now an aspiring hack machinist #9
An alternative to rotary phase converters are VFD's (Variable Frequency Drives) They convert single phase 220VAC to three phase 220 and let you vary the motor RPM and reversing electronically.
GS1 (120 / 230 VAC V/Hz Control) Overview
They are not difficult to install.
I also have the luxury of the totally separate 1 hp Horizontal motor arbor as well (the vertical motor is 1.5 hp). That said, I do lack the axle arbor and the wishbone bracket but it can still be used for some things with just a collet set only like the vertical. Maybe some day I will make the wishbone for the horizontal since there is a slim to none chance that I will ever find one).
Tool holders are in the wood box. NMTB 30 spindle taper to ER-32 style collets.
2013 RAM 4500 (A50323)
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
LOT NUMBER 250 (A53084)
LOT NUMBER 250...
(1) 330 GALLON POLY TOTE W/ CAGE (A51248)
(1) 330 GALLON...
16ft T/A Flatbed Equipment Trailer (A50322)
16ft T/A Flatbed...
