H2 or H3 hydrauliics
   / H2 or H3 hydrauliics #1
larryd314
bella vista ar
81 jd314 garden tractor
Has any one had any experience changing out a h1 system on a jd 314 from a jd316,317? My 314 has a h1 system and I need at least an h2 for my 314 to operate the angle part of my blade I recently bought
Any imfo would be appreciated.
Thanks
larryd314
   / H2 or H3 hydrauliics #2
What is H1,H2 and H3?
   / H2 or H3 hydrauliics #3
The valves for 317 don't show to fit a 314 but I think they could be made to fit. I saw no H2 for any models you mentioned. I know the 140 had H1 & H2
Tx Jim thanks for your imfo. I have seen a couple 314s with h2 but wasn't able to ask about them though. I did notice the control handles were a different style.
larrryd314
   / H2 or H3 hydrauliics #6
H1 is a single spool valve H2 is a dual spool valve H3 is a triple spool valve
I was thinking that was it, but didn't know for sure. Thanks
   / H2 or H3 hydrauliics #7
This parts photo for the hyd lines on a 314 is the only one listed in PC #1618 and as you can see the lines for frt/rear couplers are merely teed in to deck lift valve. I owned a 314 from '87 -'13 when I bought a zero-turn.
HTH's,Jim
2011 Toyota Corolla Sedan (A53117)
2011 Toyota...
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A52706)
UNUSED CFG...
UNUSED SDLANCH SDLC2030FT ALL STEEL CARPORT (A54757)
UNUSED SDLANCH...
2013 Ford F-550 4x4 Ext. Cab Service Truck (A55788)
2013 Ford F-550...
1831 (A51247)
1831 (A51247)
202107 (A54756)
202107 (A54756)
