>> H-F QUICK HITCH !!!! <<
   / >> H-F QUICK HITCH !!!! << #1
BearKiller
Well, it finally quit pouring the rain long enough for me to run a little test on my shiny new H-F quick-hitch.
In the mean time, I have reamed out every other hole for the J-hook to 5/8 and re-drilled the J-hook holes 11/16, such that instead of the supplied metric bolts, I now use 5/8 hitch-pins.
I was afraid drilling all the holes to the larger size would not leave enough metal between the holes, so I opted to do the top and bottom ones, and skip every other hole, thus having four re-sized holes.
I looked closely at various peoples pictures of the top-link adapter and welded up one for myself.
Looking ahead, I had screwed a plywood base to the end of a scrap length of pallet cant, about five by seven, maybe eighteen inches long, such that this became a support leg to hold the front end of the six-foot grader-blade at about operating height, instead of laying on the ground.
As the builders plate is illegible, and it is heavy as sin, I have no notion of who manufactured this ancient blade, but it fits the quick-hitch as though purpose-built for it.
The only draw-back is, due to a design necessity, the top J-hook will not work, so I have to use the top-link adapter.
So, with quick-hitch mounted, I backed up to the blade and was able to easily hook it up without leaving the operator's seat.;)
The orange 4-foot King Kutter bush-hog is not going to be so easy, as no piece, part, or particle of it comes even close to mating with the quick-hitch; no problem, as I have already got hitch adaptations drew out on paper and plenty of new steel laying on the floor; when I get done, it will work as planned.:cool:
Thanks to everyone that has given advice, posted pictures, and convinced me that I could not live without a quick-hitch.:)
   / >> H-F QUICK HITCH !!!! << #2
sounds like a fun project. However we LOVE pictures and would love pictures of your progress.
   / >> H-F QUICK HITCH !!!! << #3
I really like the HF quickhitch but it does seem that I have to modify each implement initially to fit. Some get longer Cat 1 pins and others get rebolted. The most interesting was my KingKutter 7' rake -- it required longer Cat 1 pins with one inside and one outside and now my top link connects to the side. Works fine but different...
Alas, I am not yet computer-savvy enough to do pictures.
I really need to learn how.
I really like to look at others pictures and should learn how so I can also share mine.:confused:
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2019 CATERPILLAR 259D SKID STEER (A60429)
2019 CATERPILLAR...
Cushman Electric Cart (A55851)
Cushman Electric...
2017 VOLVO VNL64T TANDEM AXLE SLEEPER TRUCK (A59905)
2017 VOLVO VNL64T...
17101 (A55851)
17101 (A55851)
2018 KOMATSU WA200-8 WHEEL LOADER (A60429)
2018 KOMATSU...
