GX75 brake pads
/ GX75 brake pads #1
steveky
Philpot, Ky
Kubota/ L3010HST, BX 1800
Anyone ever replaced the brake pads on a GX75 rear rider. Do you have to remove the disc to replace the pads? /forums/images/graemlins/confused.gif
/ GX75 brake pads #2
If i remember right that has the pearless 5 speed trans. Remove the brake assy. Slide off the disc r+r inside brake puck and same with outside. Readjust with bolt in center of brake assy. and that's it.
/ GX75 brake pads
I can't seem to get the disc off the shaft. I've removed what was left from the old pad but this doesn't help. I'm wondering if my shaft is sticking out too far and I've got other problems to. I called JD about purchasing a tech manual...they want $95 for one of those...wow...Guess I'm gonna have to haul it to the dealer. Its a good mower but not sure I want to invest much in a 12 year old mower.
Thanks for your help.
/ GX75 brake pads #4
Can you take a picture of your problem? I'm sure we can come up with a solution for you.
/ GX75 brake pads #5
Try hitting it with penetrating oil for a few days and give it a few <font color="brown"> taps </font> with a hammer. It needs to slide on the splines to work properly.
/ GX75 brake pads
Got that mower going and saved the price of a new one. The JD dealer didn't want to offer any information on repairing this mower but did offer to fix it if I brought it in. I went down there and was looking at the new version of my mower and would you believe they have the same transaxle and brake set up. Its amazing what one little washer in the wrong spot will do...lol. I told them I was just looking...thanks anyway guys.
Have a great day.
Steve
Case TV380 (A62177)
Case TV380 (A62177)
3 Point Hay Forks (A62613)
3 Point Hay Forks...
2018 HINO 338 KNUCKLE BOOM TRUCK (A63276)
2018 HINO 338...
Purdy PT 60' Land Leveler (A64126)
Purdy PT 60' Land...
Wolverine TL-12-72W 72" Skid Steer Tiller (A62679)
Wolverine...
2009 PROCO 130BBL (A65643)
2009 PROCO 130BBL...
