GX345 Won't Start
/ GX345 Won't Start #1
jiverson90
KY
2003 John Deere GX345
Hello Guys,
I was the guy with the GX345 a month or so ago that was having some issues with my mower. I decided to take it to my local dealer just to have them do a service and to fix the issues I was having.
Now they rebuilt the carb, new fuel pump, gaskets where the oil was leaking, voltage regulator, transmission service, and standard service. Since I purchased this mower at a deal from a friend, I decided just to give it a good service and have my dealer here do the work.
Picked it up on Thursday and they drove it on to my trailer and couldn't wait to mow again.
I immediately get home to take the mower off the trailer....doesn't start. Cranked, but very slowly. Called my service guy he said "charge up the battery and you should be good to go". Charged it up at a slow amp setting and measured over 12v. Tried to start it again yesterday afternoon cracked faster like it normally should, but still didn't start. Called him back up said it won't start after charging it. He said well it's most likely your battery, bring the battery in and I'll give you a new one just because. So, I came to the store today, picked up my free new battery, came back home, hooked it up, tried to start it. Nothing. Cranked like it should, but still didn't start.
To say that I am frustrated is an understatement and I called the dealer and told them and spoke to a technician who worked on it some. They will come pick it up for me Monday but didn't know what I could do in the meantime to troubleshoot it.
/ GX345 Won't Start #2
Sorry to hear of continued problems.
Should just continue and add to your old thread... next time.
/ GX345 Won't Start
I didn't for its seems to be a complete different issue. I'll take note for next time.
/ GX345 Won't Start #4
I know the story...it the one the dealer uses 90% of the time. The technician probably started the day before he put his hands on the tractor, and that is common for a tractor the dealer was to fix and you paid your last dollar for the benefit it would work when you got home. Now, they come and get it...another fee for hauling it in, plus the fact you will probably pay some more of the last few dollars you have, as they will tell you this is something (repairs) that wasn't part of the original job work order. Been There.
/ GX345 Won't Start #6
Well, assuming that it's timed correctly, you need compression, spark, fuel and air for it to run. I assume that it's timed correctly since they drove it on to your trailer when you picked it up. So what can happen in transit??? I believe that you have a fuel cut off solenoid on that carb. Is it opening?? Can you hear it click when you turn the key to start it?? Do you get spark when you try to start it???
You can remove the fuel cut off solenoid if it's not working and just plug the hole. If that was the problem, it should then start and run.
/ GX345 Won't Start #7
Why would John Deere put a "thingy thing" on a lawn tractor that would shut off the gas? When the owner turns the key to off, that surely would shut down the engine. But, we know the story... it's to keep the tractor from "backfiring" at shutdown like some lawn tractors we have own. The backfiring would disturb the male and female next door from have their afternoon delight round, and they surely would complain.
Yep!, just remove the shutoff value and plug the hole in the carburetor. However, to keep those two lovers next door from complaining, just run the tractor at idle for a couple minutes before turning the key off.
/ GX345 Won't Start #8
OK the most common 2 things from when I work at a jd dealer for 5 years on 345s and 425s is a thing called a timer delay relay. There 20 bucks and easy to change, I don't know your story but the dealer I worked at didn't screw people but I have found there are some that do and don't care. The other thing that could happen was with the key switch module. There are fuses on the key switch module so I would check those and I would check for spark.
/ GX345 Won't Start #9
I would say bad coil but it should still run on one cylinder so maybe your have a fuel flow problem as well
/ GX345 Won't Start #10
Check the electronic ignition components out. From the crank pickup, to the electronic points (or mag on some), to the coil(s). Sounds like a part has failed due to age/heat and dies quickly after warming up.
/ GX345 Won't Start
This is what happened the first go around when I took the mower in. It ran 30 minutes. Stopped running and couldn't start it back up.
So when it happened the first go around, I called the dealer and took it in to be looked at. They determined that it was a carb problem so they then rebuilt the carb, new fuel pump, voltage regulator, new battery, and a full service (transmission service, oil and filter, air filter, sharpened blades, etc). Ran me 1000 bucks.
So I pick it up, got home and it wouldn't start. They didn't even put enough gas in it for me to get it off my trailer. So I put gas in it, and it still wouldn't start. Took it back they said there was "water" in the gas, they filled it up and it was good to go.
Started mowing today, made it about 30-45 minutes.....stopped running. Same thing it did the first go around before I took it in the first time. Any ideas?
/ GX345 Won't Start #12
Any chance there's debris in the tank that could be getting sicker up then floating away and plugging the fuel line. Or maybe put all new fuel line on it. It's getting some age I have seen the black fuel lines separate and not leak or anything but wouldn't flow fuel.
/ GX345 Won't Start #13
Check the main board that is mounted to the right of the battery. That board holds all the relays, resistors, etc and is prone to wearing out due to both heat and moisture. When they start to go you will get some of the symptoms you described. I've had to replace mine twice on my "non-GX" 345 (over the span of about 20 years though so not too bad IMHO!). The dealers usually want around $90 for them but you can find them online for cheaper. You can change it out yourself.
/ GX345 Won't Start #14
I would say it is the Time Delay Module. Go out and take a screw driver or something that you can "tap" slightly on the TDM and try to restart the tractor. If it starts, you found the culprit. However, lets go with that it may also be the ignition-module with the key switch attached. If it quits again, tap the TDM again and it is starts... we know for sure it's the TDM.
/ GX345 Won't Start
John Deere GX345 Issues - YouTube
See this video of my mower this morning. This is a cold start after letting it sit all night. Starts but runs super rough amd seems to surge and died within 5 seconds.
2019 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A64553)
2019 ASV RT-25...
LOOK! (A65640)
LOOK! (A65640)
2008 Honda Civic Coupe (A64557)
2008 Honda Civic...
New/Unused Landhonor 24in Semi-Automatic Tire Changer (A65583)
New/Unused...
2005 Chevrolet Silverado Service Truck, VIN # 1GCJK33245F911286 (A65563)
2005 Chevrolet...
1987 FORD F-8000 ROLLBACK TRUCK (A64277)
1987 FORD F-8000...
