GX345 oil problem
/ GX345 oil problem #1
abellia
CAMBRIDGE
gx345, 4020
Hi,
I've got a GX345 that is forcing oil up out of the fill tube (by the dipstick cap). It seems to run fine. Also, the battery light comes on and stay on for much of the time, though this has been happening for longer than the oil issue.
Thoughts?
/ GX345 oil problem #2
Welcome to the TBN
For how long have these two things been happening? moments? days? weeks? months?
/ GX345 oil problem
The battery light was going on last year. No starting or running problems.
The oil leaking I've noticed over the last month but wasn't sure where it was coming from or how much.
/ GX345 oil problem #4
So it is it a couple drops of oil to the floor after mowing for an hour or is it enough you have to add oil to mow the next time. How many hours are on it? How long has it been since the oil was changed? What size deck? (The larger the deck the sooner the engine will start showing signs of wear.) How often do you change the oil and filter? What grade of oil is it?
/ GX345 oil problem
At this point it comes out in a small stream. I haven't changed the oil filter this year. Could the filter be plugged? Could the gasket on the dipstick just be crap? How much pressure is there normally in there?
/ GX345 oil problem #6
You may have a filter problem. I would change the oil and filter and replace the dipstick gasket if you can that will only cost 30 bucks or so. otherwise your going to be looking at internal parts or valve adjustments.
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
2010 Ford F-350 Crew Cab Diesel (A62679)
2010 Ford F-350...
2017 Genie GTH-636 (A62177)
2017 Genie GTH-636...
2015 Ford F-250 Pickup Truck (A61567)
2015 Ford F-250...
2018 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2018 VOLVO VNL 6X4...
250 Gallon John Deere Sprayer (A65579)
250 Gallon John...
