Guess a newby has to be in the clic to get an answer on here.
   / Guess a newby has to be in the clic to get an answer on here. #11
Like the whole panel is either on or off? I'd strongly recommend having a savvy friend look at the power leads where they're soldered to the board and checking your grounds. Spending 5 bills on a hunch can't end well.
   / Guess a newby has to be in the clic to get an answer on here. #12
If it sometimes works and sometimes doesnt...it sounds like problem might be in the grounding or other power leads.
   / Guess a newby has to be in the clic to get an answer on here. #13
Go for the Ground. What are the chances that two separate sending units would be bad. I do not have to play dumb, but I have alot of smart friends who might have the answer on here.
   / Guess a newby has to be in the clic to get an answer on here. #14
Solder joints on printed circuit boards are common to break and make intermittent contact with changing weather, vibration etc. That would be my first thing to look at as long as you have everything you need for the cluster to work up to the back of it (power ground, gauge inputs)..
Ok. Thanks. Im getting ready to take the panel out anyway. Checked the ground and it is ok.
   / Guess a newby has to be in the clic to get an answer on here. #16
if it sometimes works.. i'd look for a cold solder or bad connection, or a marginal component inthe power system feedingit.
I bet a guy that knew his way around a vom and solder iron could really help out here.
as a last resort.. a salvage yard like wengers of PA *MIGHT* be able to find one cheaper than mtd prices..
good luck
soundguy
Ok. Thanks a bunch.
   / Guess a newby has to be in the clic to get an answer on here. #18
take a magnifying glass and check all solder joints real close. my sister in laws dodge caravan started acting up not starting and i traced it to the cluster and found a solder joint that was cracked in a complete circle. a little heat and some solder and the vehicle has not messed up anymore.
2021 FORD F-150 STX (A55745)
2021 FORD F-150...
Erskine Skidloader Truss Boom (LIKE NEW) (A50775)
Erskine Skidloader...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A55302)
2023 New Holland...
2012 Ford Escape Limited SUV (A53424)
2012 Ford Escape...
2003 Lincoln LS (A50324)
2003 Lincoln LS...
2022 Third Coast Reversible Plate Compactor (A54865)
2022 Third Coast...
