GT275 wont restart
   / GT275 wont restart #11
</font><font color="blueclass=small">( If it is working, great! But your description of it running fine, and then when shut off, not being able to restart for an hour is classic symptoms of a failing coil. Once the coil gets hot, it's ability to make spark weakens, but one cooled down it will provide enough spark to start the engine. I am assuming the battery is good as is the charging system? )</font>
Bontai,
First off, hello again:)
I think the original poster is saying that the tractor would even turn over(like how mine has had a bad connection at the PTO switch). No turn over, Definitely won't get spark. Now if it turned over and then wouldn't start....that's another story.
Chad
I am pretty ignorant about these sorts of mechanical things but it seems like there were two problems.
At first the tractor would start with no problem and run well. However, when it was shut off to empty the clipping bags it would not restart unless you left it alone for a while. Then.....started up with no problem.
Then one day I came out to start it and when I turned the key none of the lights on the dash lit up and there was no indication of any power. I tried jumping it and the battery seemed ok but nothing. So I looked at the little plunger under the seat and it seemed ok and so I tried the button that starts the lawn mower. First I push down and it seemed like was already down. Then I pulled up and all the lights on the dash came on. I knew I could not start in the up position so I pushed it down, the lights went out but it still would not start. Tried pulling up on the mower button and this time the lights did not come on.
I am still ignorant but I dont think a pitted carb is going to have much to do with the electrical. Those have really been my only problems with the GT so I am pretty lucky all in all.
Mark
Husky GHM105890 Cement Mixer (A49461)
Husky GHM105890...
Flat Deck Trailer (A50322)
Flat Deck Trailer...
Komatsu D39PX-24 Crawler Tractor Dozer (A49346)
Komatsu D39PX-24...
Ranch Hand Pickup Truck Grill Guard (A49461)
Ranch Hand Pickup...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2012 FREIGHTLINER CASCADIA (A50854)
2012 FREIGHTLINER...
