GT275 will not start - will not turnover
   / GT275 will not start - will not turnover #1
mr30217
John Deere GT275
I have a GT275 that was running fine. Only problem was dead battery. Then the blade clutch bolt broke (again). I ordered the bolt and put it on. I could crank the mower but could not get the blade clutch to engage. I found some info that said the clutch has to have 12v to engage. I replaced the battery with a new one. It cranked fine and the blade clutch engaged. I cut about an acre of grass. I started on the remaining 3 acres and the blades would disengage. I would push in the blade switch and wait a few seconds and pull it out again and the clutch would engage again. This on and off for the clutch went on for about an hour. I was cutting a thick patch of grass and the mower went dead. When I tried to crank it I got nothing. Even the dash panel lights would not come on when the key was turned to the on position. The first thought that came to mind was a fuse. But with the blade clutch needing 12v to stay engaged and the problems I had with the blades cutting of and the reengaging when I reset the engage switch it would seem that if this was a fuse it would not allow me to restart the blades. I tested the power from the battery to the starter and got 12v and I checked continuity from the negative terminal to ground and it was good.
Any suggestions?
   / GT275 will not start - will not turnover #2
first place I would check is the switch on the elec PTO. The ignition switches go bad on occasion as well. You can test by jumping a wire from the battery to the starter, but be super careful doing it.
2014 Lincoln MKX SUV (A48082)
2014 Lincoln MKX...
2008 Mazda CX-9 SUV (A48082)
2008 Mazda CX-9...
2007 Volvo VNL Truck Tractor (A51039)
2007 Volvo VNL...
2012 MACK PINNACLE (A50854)
2012 MACK PINNACLE...
Okada Top 270 Hydraulic Breaker (A50860)
Okada Top 270...
2011 John Deere 844K Articulated Wheel Loader (A50322)
2011 John Deere...
