GT275 will not start - will not turnover
   / GT275 will not start - will not turnover #1
mr30217
John Deere GT275
I have a GT275 that was running fine. Only problem was dead battery. Then the blade clutch bolt broke (again). I ordered the bolt and put it on. I could crank the mower but could not get the blade clutch to engage. I found some info that said the clutch has to have 12v to engage. I replaced the battery with a new one. It cranked fine and the blade clutch engaged. I cut about an acre of grass. I started on the remaining 3 acres and the blades would disengage. I would push in the blade switch and wait a few seconds and pull it out again and the clutch would engage again. This on and off for the clutch went on for about an hour. I was cutting a thick patch of grass and the mower went dead. When I tried to crank it I got nothing. Even the dash panel lights would not come on when the key was turned to the on position. The first thought that came to mind was a fuse. But with the blade clutch needing 12v to stay engaged and the problems I had with the blades cutting of and the reengaging when I reset the engage switch it would seem that if this was a fuse it would not allow me to restart the blades. I tested the power from the battery to the starter and got 12v and I checked continuity from the negative terminal to ground and it was good.
Any suggestions?
   / GT275 will not start - will not turnover #2
first place I would check is the switch on the elec PTO. The ignition switches go bad on occasion as well. You can test by jumping a wire from the battery to the starter, but be super careful doing it.
2011 Ford F-250 4x4 Pickup Truck (A50323)
2011 Ford F-250...
71066 (A49346)
71066 (A49346)
2021 John Deere R4038 Self Propelled Sprayer (A50657)
2021 John Deere...
2016 Ford Explorer AWD SUV (A48082)
2016 Ford Explorer...
2025 K2030 UNUSED Metal Garage (A50860)
2025 K2030 UNUSED...
2011 Kia Optima Sedan (A50860)
2011 Kia Optima...
