GT275 PTO Engaging Intermittently
   / GT275 PTO Engaging Intermittently #1
snpower
Charlottesville, Virginia
John Deere GT235, GT 275, 1025R
Symptoms are PTO not engaging or engaging and then disengaging at random times.
I have followed the WSM to check the PTO switch and the current draw coming out of the harness side. The switch matches battery voltage, the current draw is 2.2 amps which is a tad below the range specified.
I believe I have a bad "blue: wire; moving it by hand with the PTO switch ON results in the clutch engaging. I'm not too sure/confident about how to run a new wire//bypass the existing one, looking for input. I did price out an entire wiring harness for the tractor which is pricey.
Thank you.
   / GT275 PTO Engaging Intermittently #2
Your choices here are pretty much 1) weak battery 2) intermittent switch 3) harness issue 4) worn clutch. You can run an Ohm test on the clutch itself, I'd have to dig on spec. Is the outside ring on the clutch adjustable? Too much of a gap can be an issue. If it was, it would have 3 nuts.
I would have thought if wiggling a wire caused it to engage with the PTO switch checking out OK it would be in the wire.
1989 Freightliner FLD120 (NEW CAT 3406A, NEW REAR ENDS, CLUTCH) (A51039)
1989 Freightliner...
2009 Mazda 5 Van (A48082)
2009 Mazda 5 Van...
2015 Volkswagen Jetta Sedan (A48082)
2015 Volkswagen...
2008 International 8600 T/A Day Cab Truck Tractor (A48081)
2008 International...
2015 FORD F-250XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-250XL...
2012 FREIGHTLINER CASCADIA (INOPERABLE) (A50854)
2012 FREIGHTLINER...
