GT2550 runs 100 feet then stops
   / GT2550 runs 100 feet then stops #1
rau2009sch
Monett, MO.
Cub Cadet GT 2550
My Cub Cadet GT2550 with Kohler Command engine starts, revs up nicely, runs with power for 100 feet, then engine dies. Just goes pooohhh then stops, at times goes BANG! then stops. Any ideas?? It restarts easily, then does the same thing. Will restart again, then do the same thing. New gas, with ethanol, 125 hours on engine. Regular oil changes. [ Before you blame the ethanol, every thing on the farm uses ethanol gas, lots of Kohler engines, Stihl engines, Farmall engines, Chevy trucks. Never a PROBLEM. ]
Thanks, guys / gals.
   / GT2550 runs 100 feet then stops #2
Could be a fuel supply problem:
1. Trash restricting the outlet at the tank
2. Partially clogged fuel filter.
3. You've got low hours, but on one of mine, the OEM molded 90-degree hose from the steel fuel line to the carb had disintegrated internally and was clogging itself.
4. Somehow float level is set too low or a piece of trash in the seat.
jack vines
   / GT2550 runs 100 feet then stops #3
chk for plugged vent on yer fuel tank cap....
   / GT2550 runs 100 feet then stops #4
FWIW - my GT2550 had a wired in the harness that was grounding out and would kill the engine. I had no idea what it was, changed the gas filter and lines, cleaned the carb, cleaned then changed the fuel cap. Finally took it to my dealer who found the issue with the wiring, corrected it and didn't charge me (it was just out of warranty by about 3 months)
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
2019 PJ TRAILER 32FT GOOSENECK (A55745)
2019 PJ TRAILER...
2014 Jacobsen AR3 3-Deck Commercial Rotary Mower (A56857)
2014 Jacobsen AR3...
2002 International 9200i Truck (A56435)
2002 International...
Hook & Cable Strap (A59076)
Hook & Cable Strap...
2007 Sterling L9500 National Crane 1800 40 Ton Tri Axle Telescopic Crane Truck (A55973)
2007 Sterling...
