GT235 stall
/ GT235 stall #1
JJZ 109
Lake Ontario/St. Lawrence River
Kubota BX2380/LA344 loader/60" MMM, Bobcat S185 skid steer, JD X394 4 wheel steer mower
A couple of months ago I bought a 1999 GT235 in pretty nice shape. It had a beat up Pirahna 44 inch deck that someone had swapped blades on and made it a rear discharge. I bought a brand new 48C deck complete and installed it.
It's been working fine but yesterday and again this morning it will either stall or nearly stall the motor when I engage the blades. Sometimes it stalls it and sometimes it will be close to stall but will pick it up and operate normally.
The deck is clear of grass buildup and I greased all fittings on the deck before I installed it. Anyone seen this or have any ideas?
/ GT235 stall #2
I have a 2004 GT235 have you checked back/rear pulley/clutch that is fed from front pulley that comes direct from motor shaft ? Maybe its locked frozen and not slipping before initial engagement.
Boone
/ GT235 stall
Boone
A couple of times this morning it wanted to stall and a couple of other times it took right off.
/ GT235 stall #4
Is this mostly just when the engine is cold?
If so you can choke it for 1 second simultaneously with the pto being engaged.
/ GT235 stall
Yes, usually upon a cold start. I guess that I haven't tried it when the engine has warmed up because once it goes, I mow until it's done and then shut it down. I haven't tried to engage blades with a warm engine but I will now that you mention this.
2006 INTERNAITONAL 7600 6X4 T/A DUMP TRUCK (A66091)
2006 INTERNAITONAL...
2019 DRAGON ESP 150BBL ALUMINUM (A60736)
2019 DRAGON ESP...
20 Yard Roll Off Dumpster (A65579)
20 Yard Roll Off...
2013 PETERBILT 367 MIDROOF SLEEPER (INOPERABLE) (A65643)
2013 PETERBILT 367...
Case 90XT Skidsteer Loader (A66285)
Case 90XT...
2007 VOLVO VHD QUAD/A VACUUM TRUCK (A59914)
2007 VOLVO VHD...
