GT 5000 Idiling Problems
   / GT 5000 Idiling Problems #1
jshine42
Sandpoint, Idaho
Craftsman GT 5000
Hello All. I'm new here but i have a problem with our GT 5000 Yard tractor. we have arpx 3 acres of lawn to mow here and our GT 5000 has run flawlessly the past 5 years; however, this year it developed a intersting problem. It starts up fine but when it's warmed up it acts like it wants to die and then it gets a shot of gas and revs back up. so it cycles like it wants to die then fires back up. And when I kill it it backfires. Anyone out there heard of this? and the answer is yes I did run Ethanol added fuel in this guy without a fuel Stabelizer. Any direction would be great. I use this tractor to maintain this property(not mine) and I just recently inheritied the tractor to use. Any direction would be great. I just changed the Oil/Oil Filter, Air Filter, and Spark plug. I was going to do the fuel filter and full fuel system flush. Any help would be great.
   / GT 5000 Idiling Problems #2
Change the fuel filter as you plan because after 5 years, it's over due. Also, get some "sea foam" from your local auto parts store or Walmart and add 3 Ozs to your fuel tank. Keep us posted for further suggestions.
Jim
   / GT 5000 Idiling Problems #3
you didnt mention what motor, if it is a kohler, shut down should be at 3/4 throttle to prevent a backfire, not at low idle like you would think. also after adding the seafoam, try running with the choke slightly on to help with the running problem and give the cleaner a chance to work.
2011 John Deere 5075 4WD Agricultural Tractor (A52377)
2011 John Deere...
Mobile toilet with shower (A53424)
Mobile toilet with...
2020 BOBCAT T770 SKID STEER (A52705)
2020 BOBCAT T770...
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A51243)
(INOP) JOHN DEERE...
2016 Freightliner M2 106 Cab and Chassis Truck (A52377)
2016 Freightliner...
