GT 2550 Review / Oil Change Valve
   / GT 2550 Review / Oil Change Valve #21
JSharp said:
I can't imagine running plain air in such a high speed machine...
I use pure, natural spring air, filtered to perfection by the nature-loving folks at Perrie-aire.
   / GT 2550 Review / Oil Change Valve #22
Actually, changing automatic transmission fluid at the required interval is VERY important.
If left to the point where it is worn out, changing it at that point can actually cause the transmission to fail. This is a well documented fact.
Something about the varnish and other junk of the old fluid actually maintaining the obnormally worn parts (due to the lack of service), and when it's removed the new fluid can't do the same thing and the transmission fails.
I hear it happens pretty quickly too.
-Larry
LBrown59 said:
How many of you change the tranny fluid in your car or pickup?:)
   / GT 2550 Review / Oil Change Valve #23
Larry
Problem with this statement is there is no required intreval specified in the CC owner/operator manual.:confused:
   / GT 2550 Review / Oil Change Valve #24
Ah, that explains it. That's probably a better choice than even nitrogen...
:D
   / GT 2550 Review / Oil Change Valve #25
And they're probably right to not have one. The periodic filter changes and the required top up oil is likely adequate provided the system doesn't become contaminated. Our little Cubs don't have internal clutches or brakes to throw quantities of wear metals into the system...
   / GT 2550 Review / Oil Change Valve #26
I was referring to the automotive statement :)
-larry
   / GT 2550 Review / Oil Change Valve #27
I change my hydro fluid once a year whether it needs it or not.
Michael
   / GT 2550 Review / Oil Change Valve #28
Then I'd probably be plenty safe changing it every 500 hours rite!
   / GT 2550 Review / Oil Change Valve #29
I would say yes, more than safe. If they wanted it changed at particular intervals I'm sure they'd say so. They could sell more $9 a quart Drive System Fluid that way...
   / GT 2550 Review / Oil Change Valve #30
then Just buy a new tractor every 300 hrs - and be done with it.
Are puting on shoes in the morning as difficult for you?
(2) METAL & WOOD STORAGE RACKS (A52708)
(2) METAL & WOOD...
Globel Industrial 44" Water Cooled Fan, 24" Electric Pedestal Fan (A59076)
Globel Industrial...
1998 FREIGHTLINER FL50 SPORT CHASSIS (A56129)
1998 FREIGHTLINER...
2007 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A58214)
2007 INTERNATIONAL...
40' High Cube Multi-Door Container (A53314)
40' High Cube...
FRONT WHEEL SPACERS (A52708)
FRONT WHEEL...
