Gt 235 surging problem
/ Gt 235 surging problem #1
FORWHEELER120
john deere gt235
I have a JD GT 235 with the 18 HP briggs and stratton engine.
It just started surging at anything other than full throttle.
Any ideas?????
/ Gt 235 surging problem #2
Might be a restriction in fuel flow, try opening the main 1/2 turn or better yet pull the gas line and run it on 100% sea foam till it smokes like a bad bonfire and let it sit overnight, reconnect everything and it should smoothen out.
OK WILL TRY THE SEA FOAM. HOPEFULLY IT WORKS. THANKS
/ Gt 235 surging problem #4
I agree too,that it's probably fuel related. If the Seafoam,doesn't cure the problem,you may be looking at a carb removal/cleaning. Could be a piece of dirt lodged somewhere.
Greg
John Deere 825I (A64127)
John Deere 825I...
New/Unused AGROTK Wheel Balancer (A65583)
New/Unused AGROTK...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2013 INTERNATIONAL DURASTAR 4300 M7 SWEEPER TRUCK (A63276)
2013 INTERNATIONAL...
2011 John Deere 5085 70HP Utility Tractor (A60352)
2011 John Deere...
2021 CATERPILLAR 730 OFF ROAD DUMP TRUCK (A62129)
2021 CATERPILLAR...
