Gt 235 surging problem
/ Gt 235 surging problem #1
FORWHEELER120
john deere gt235
I have a JD GT 235 with the 18 HP briggs and stratton engine.
It just started surging at anything other than full throttle.
Any ideas?????
/ Gt 235 surging problem #2
Might be a restriction in fuel flow, try opening the main 1/2 turn or better yet pull the gas line and run it on 100% sea foam till it smokes like a bad bonfire and let it sit overnight, reconnect everything and it should smoothen out.
OK WILL TRY THE SEA FOAM. HOPEFULLY IT WORKS. THANKS
/ Gt 235 surging problem #4
I agree too,that it's probably fuel related. If the Seafoam,doesn't cure the problem,you may be looking at a carb removal/cleaning. Could be a piece of dirt lodged somewhere.
Greg
2016 Manitou MHT10230 50,000lb. 4x4 Rough Terrain Telehandler (A60352)
2016 Manitou...
Tafe 45DI (A60462)
Tafe 45DI (A60462)
John Deere 6300 (A60462)
John Deere 6300...
2009 BMW Sedan (A61569)
2009 BMW Sedan...
2020 DRAGON ESP 150BBL ALUMINUM (A60736)
2020 DRAGON ESP...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
