gst trani
/ gst trani #1
Brian m
Barrie ONT CANADA
2002 kubota L35
Hi guys im new to this site and also to my l35 2002.
A question about the shifting of gears, how long should they pause before shifting to the next gear? Mine takes about a second or so. And I lose a little speed, also in 8th gear it seems under powered. What do you think?
thanks Brian
/ gst trani #2
That is about the same is mine. I was told the delay is intended, so the hydraulic clutch asborbs the shock gradually. 8th gear isn't real powerful, mostly road use. Whenever I've used 8th, I've always kept the RPM at 2,000-2,500. I used to live near a guy who had a L35. He beat it to death and it always ran good, they are one tough machine.
/ gst trani
Thanks for the answer wolfy
One more question, when you are in gear 7 and shift into 8 are your rpms at 2500 then it chugs a little untill up to speed?
thanks Brian
/ gst trani #4
I wouldn't say so any more so than any other gear.
/ gst trani #6
I change gears at all speeds. If I'm on the road, I usually set the hand throttle at 2,500 RPMs, then shift as needed.
/ gst trani #7
And usually I only use 8th gear for flat roads. I don't like going downhill in top gear in anything, and my tractor climbs hills better in 6th or 7th gear.
/ gst trani #8
The GST is essentially an automated manual transmission. It has a multi-plate wet clutch that is automatically disengage and engage each time you shift. When you move the range lever, the clutch is disengage, one or more shift forks move and the clutch is reengaged. That is why there is a delay when shifting. The transmission goes into neutral when the clutch is disengaged so the tractor can briefly roll. You need to be mindful of this when shifting on hills. You should back off on the throttle some when shifting to prevent excessive wear of the clutch.
2016 WEILER P385A ASPHALT PAVER (A63276)
2016 WEILER P385A...
(2) 10ft Nesting Boxes (A65579)
(2) 10ft Nesting...
HYDRO TEK PRESSURE WASHER (A65643)
HYDRO TEK PRESSURE...
2013 FORD F-550 SUPER DUTY (A65643)
2013 FORD F-550...
Hedge Posts (A65640)
New/Unused Heavy Duty Plate Compactor (A65583)
New/Unused Heavy...
