Growling in Rear End When in 2wd, not 4wd. S373D
   / Growling in Rear End When in 2wd, not 4wd. S373D #1
duwem
John Deere Garden Tractors
On my S373D (4 wheel drive, 3 cylinder diesel) tractor, while driving, especially in 3rd, I get some growling/almost a clicking in the rear of the tractor, seems to be on the right side, but only when its in 2wd, when I switch it to 4 wheel drive the noise goes away.
Ideas?
   / Growling in Rear End When in 2wd, not 4wd. S373D #2
Probably a bad bearing/gear in the tranny. Not sure about why 4wd makes it go away - there's no signficant connection between the front drive and rear gear-wise that I could see would cancel anything in the back. Maybe since the front wheels usually "lead" the rear drive it's taking most of the load off the rear making it less noticable.
Anyone have a parts breakdown showing the gears and bearings?
I dont hear it working the tractor hard in 4wd, but then I'm iin 1 or 2nd gear.
Anyone?
   / Growling in Rear End When in 2wd, not 4wd. S373D #5
Maybe when 4wd is engaged it takes some pulling load off the rear end. I don't know what it could be. I thing you will have to open it and look.
Does the cover the shift lever goes though just come off once you talk out the bolts? Anything special to get the lever to line back up when reinstalling it?
   / Growling in Rear End When in 2wd, not 4wd. S373D #7
It should. Put it in neutral before you pull the top off.
Takeuchi Skid Steer (A52377)
Takeuchi Skid...
2014 JLG G12-55A 12,000lbs 4x4 Rough Terrain Telehandler (A53421)
2014 JLG G12-55A...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
UNUSED CFG INDUSTRIAL QH12R EXCAVATOR (A52706)
UNUSED CFG...
2005 International 4300 Telsta Telescopic Bucket Truck (A52377)
2005 International...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
