schmism said:Ive heard of dual wells, pump ground water up, circulate it and pump it back down into a second well a few feet away from the first.
That is called an open loop system. While they can have the highest efficiency, due to constant water temps, issues with water quality and contamination result in much higher service and callback issues. I will not install them for that reason. If you need to spend the money drilling, I would recommend closed loop in bore holes (drilling).
Ponds with closed loop coils work well also, assuming the pond is big and deep enough to handle the heating and cooling loads.
paul
