Ground Prep for SPring garden
/ Ground Prep for SPring garden #21
Well, I have been searching for something to make raised rows as well. I have come across things named "Hilling Moldboards", "Tillrowvators", and now "Potato Hiller"...but I haven't been able to find anything that's made today. Everything I've come up with is at an auction that's just not practical for me to get to.
I know this would probably fit better in one of the other discussion groups, but what about a "special" tailgate for a 60" tiller that would funnel the tilled soil into a 48" raised bed?
Anyway, I'd love to hear what orthers use as well...as long as it's not a shovel /forums/images/graemlins/wink.gif
Sam
/ Ground Prep for SPring garden #23
I found this one (see photo) in the Agri Supply Co. catalog. It might be what some are looking for.
/ Ground Prep for SPring garden #24
/ Ground Prep for SPring garden #25
I've never done this before. Hopefully, I can figure out how to upload a photo of my rotary plow. Here it is in an attachment, hopefully. Heah, this appears simple. Did the browse, and it shows the file.
This is a pic right after I cleaned the plow up (using the rust removal by electrolysis) and repainted it. It isn't connected to the PTO. I just have in place where it would be connected.
I'm not really sure what the PTO speed of the Gravely is. It does have 2 speeds. I usually run it in low because the ground speed is too fast for me to walk if I use the 2nd speed, and the plow will throw the dirt too far!
Ralph
/ Ground Prep for SPring garden #26
It actually looks just like the "bed shaper" picture link.. except that mine has all 4 disks on the first bar.. and the bed shaper on the second bar. The brand name is "Fergason Mfr.?" I think the price was around a $1000 3 years ago.
I'd have to wait until the weekend to take pictures.. it's usually dark when I get home.
Before I got it.. I made the hills by hand w/ a hoe.. the next year I used the FEL to make the hills(garden got larger).. a lot easier then the hoe method.
I think it could be easily & cheaply made.. using an old cultivator 3pt bar.. and 2 or 4 disks blades.. skip the bed shaper section and just use a rake to smooth the top of the hills.
/ Ground Prep for SPring garden #27
The 3pt keulavator from Agri-Supply at $139 is misleading. The complete price is just over $400 which gives you 2 hillers, 2 sweeps, and 2 shanks plus mounting hardware. Just the frame by itself is $139.
They changed the catalog description for 2004. You gotta read the fine print.
/ Ground Prep for SPring garden #28
I know this is not a option for most but our 54 International cub has hillers and cultivators that do a great job as the hydraulics are also power down.You can cultivate and re hill till the plants hit the bottom of tractor which is quite high.This is one of the only jobs that we use the cub for anymore and wouldn't be without it.There are a lot of these tractors still out there for a fair price and a great reason to buy another tractor /forums/images/graemlins/grin.gif
/ Ground Prep for SPring garden #29
I have never done this and don't even have a garden but was wondering if you couldn't make the beds with a rear blade. With the soil well tilled and a rear blade at max angle wouldn't the windrows form beds. I have cut ditches with a blade and it works well to a point. Might even pay to buy a short 4' blade just for that purpose.
Do you think that it could work? /forums/images/graemlins/confused.gif
MarkV
/ Ground Prep for SPring garden #30
i use a 5' blade to make raised beds.started out with a row hipper set as far apart as possible & ended up with 4 rows.then i put the 5' blade on & pushed the 2 outside rows into the 2 inside.makes really wide ,deep beds.all the neighbors used to wonder if i was crazy,now they know for sure...revg62
/ Ground Prep for SPring garden #31
Here's a parts list for the Gravely rotary plow that might help some of you to understand what it looks like.
Ralph
/ Ground Prep for SPring garden #32
I posted a couple other places with the following 2 ideas without much response then:
1) Put a rotary plow shank into a PHD.
2) Use a single disc plow on the 3 pt. The Kubota dealer in Orange, Va had 2 or 3 of these during an open house last fall. These would be more effective to be able to "throw" dirt, as apposed to say, a modboard type plow.
Ralph
/ Ground Prep for SPring garden #33
I built this from parts salvaged off a junked-out full size field digger. Originally a pull-type implement with wheels and mechanical lift, now it is a 3-pt unit. Seven cultivator tines are enough for my JD 4100 tractor, it can dig 9" deep, and I pulled up tree roots as big as 1.5" diameter with it the first time I ran it last fall.
/ Ground Prep for SPring garden #34
Wow, jimgerken, I like that. Slap a coupla cans of krylon on it and it would look factory fresh!
I once bought a 10 ft pull type chisel plow at an auction for $40. Sold the two extensions to a guy that only wanted that (he came up to me after the sale) for $15. Cut the rest up and built a 6 ft 3PH chisel plow out of what was left, and sold the rest for scrap for a coupla bucks.
(I didn't paint mine either!)
/ Ground Prep for SPring garden #35
Yea, everyone who sees the pics says "paint it". I guess I felt that since the darn thing has sat outside all its life already, is probably older than I am, and will still outlast me, it doesnt get any paint. Maybe I will break down and waste some paint on it anyway. If it survives the Spring tillage without needing repair or modifications, I will spray something on it. I promise. /forums/images/graemlins/grin.gif
/ Ground Prep for SPring garden #36
</font><font color="blue" class="small">( I built this from parts salvaged off a junked-out full size field digger. )</font> What a great modification. I just love talent, wish I had some. John
18' Pipe Gate (A66408)
Landhero LDH-TWP80, Gasoline Water Pump (A62679)
Landhero...
New Holland 273 Square Baler (A66408)
New Holland 273...
2017 JOHN DEERE 85G MINI EXCAVATOR (A59914)
2017 JOHN DEERE...
Transfer tank (A61567)
2022 MORBARK EAGER BEEVER 1215 WOOD CHIPPER (A63276)
2022 MORBARK EAGER...
