Ground powered (tractor) dump cart
   / Ground powered (tractor) dump cart #1
bobodu
Platinum Member
Whitley County,In.EIEIO
Farmnought.Gravely Model L,Gravely Model LI,1941 Clinton two wheeler
Please don't laugh. This is a "concept build" to prove my idea. All this stuff was just pulled outta the scrap pile and will be redone now that I know it will work.
I have built many dump thingies over the years ( trailers,site dumpers and even a dump truck) and really didn't see the need for expensive hydraulics or linear actuators for a small dump trailer for yard waste and the wife's fiddlings. I knew that if you could lock the wheels and get the balance right,simply using reverse to dump and a forward gear to bring the box back down, everything could be very simple.
I used an old WheelHorse tranny that wouldn't shift for the axle and brake. You put the tractor into reverse and pull the handle to release the box. When you back up...it dumps because the box is hinged with the weight to the rear. As the box moves upwards, it pulls a tension spring and locks the axle. Pulling forward lowers the box and releases the brake. A similar arrangement could be made with a bar that locks the wheels by pressing it against the tires.
Anyway...it's another idea for you builders.
   / Ground powered (tractor) dump cart #2
Nice and simple idea looks like just the job to go behind the ride on mower for odd gardening bits
I have an old dumper that has a manual tip arrangement it is set up to roll on a set of rails welded down the side of the bucket and works really well as long as you are looking to dump the whole load thats why i just built the tipping trailer
Sometimes simple it by far the best way round a problem;)
   / Ground powered (tractor) dump cart #3
Pretty neat idea, I like it! :thumbsup:
Any problems with traction so far where you go to back up and the tires just slide along the ground? Those tires remind me of my 83 Honda Odyssey which I need to get new tires for before the snow melts. ;)
2021 CATERPILLAR 299D3 XE SKID STEER (A60429)
2021 CATERPILLAR...
Deere 335P (A53317)
Deere 335P (A53317)
PALLET OF (4) SETS OF 18"X78" BIFOLD DOORS (A60432)
PALLET OF (4) SETS...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
(2) UNUSED 460/85R30 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
2021 XCMG CV123PDU ROLLER (A60429)
2021 XCMG CV123PDU...
