Ground Hogs
/ Ground Hogs #41
I can only imagine. How long will your vision be messed up?
It depends on how dry they are before I realize I need the drops and which drops I use. Probably between one and thirty minutes before they get as good as they're going to get. The thin drops work faster while the thick ones last longer.
/ Ground Hogs #42
It depends on how dry they are before I realize I need them and which drops I use. Probably between one and thirty minutes before they get as good as they're going to get. The thin drops work faster while the thick ones last longer.
Ah. My wife has dry eyes. Has to put drops in each morning. Not sure about afternoons. Doctor prescribed stuff.
/ Ground Hogs #44
Had a problem with groundhogs going under buildings where smoke bombs don't work. The trap I used did not get them baited with apples etc. Changed the bait to canned peaces in heavy sirup and made a trail to the trap. Worked perfectly and 5 groundhogs disappeared. Also don't clean the trap after use so the smell of GH lingers and the fear of the trap id less
/ Ground Hogs #45
Caught another one last night. Pretty ingenious little critter. Was hidden behind a row of canna lilies. Went under a chain link fence, under the black plastic that’s under the rocks that’re under our deck for our above ground pool. Probably nice and dry in there. Had my wife not noticed just a small pile of sand near the front of the triple line of lilies while weed eating, we’d have never known it was there.
Set trap between lilies, baited with cut apple. That’s two for two with the apples.
/ Ground Hogs #47
I "caught" one Sunday night. It's been a while since I've fired much and I kept missing. Then I wounded the little bugger... I've never heard the noises he made. Luckily I had one round left and put him out of his pain, but it will be a while before I use my MarkII on one again.
/ Ground Hogs #48
Too many house around here to responsibly shoot at anything. I yelled at it and gave it a generally bad experience before I let it go in the way back.
/ Ground Hogs #50
That's most likely how mine got here... I live out in the "way back". I take care of one every 4 or 5 years, so it's not like they are reproducing here. Growing up they were a nuisance and it never bothered me to get rid of them. I guess that I'm getting old.
By ‘way back’ I meant behind the garage. :ROFLMAO:
/ Ground Hogs #52
I use a Have A Heart trap with two open ends, then take em' for a ride. Otherwise, it's lead poisoning.
/ Ground Hogs #53
Post your address & I'll bring the ones I trap over to your property.
/ Ground Hogs #54
I usually release them on state game lands a few miles from my place. I can give you directions but it's a long ride from MI. :)
/ Ground Hogs #58
Put concrete block on top of trap, or run a couple rebars through it side-to-side near the bottom, then put concrete blocks on the rebar.
Also, leave the trap locked open for a couple days but keep baiting it. He’ll get used to going in and out. Then take the lock off one day.
/ Ground Hogs #59
Ground Hogs
HYD OIL, OIL & USED OIL TANKS (A60429)
HYD OIL, OIL &...
2014 JAYCO JAYFEATHER TRAVEL TRAILER (A63569)
2014 JAYCO...
2020 ISUZU NRR 4X2 S/A 22FT BOX TRUCK (A59912)
2020 ISUZU NRR 4X2...
2014 MERCEDES 2500 CARGO VAN (A59911)
2014 MERCEDES 2500...
2018 Kenworth T880 Quad Dump (A62613)
2018 Kenworth T880...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63118)
2017 Yale GLC050VX...
