ground clearance of 59" blower mount?
   / ground clearance of 59" blower mount? #1
defed
WNY, USA
i have to get going on finishing the necessary mods to my 59" blower before winter gets here. i know i asked this before, but can't find it now...what is the clearance of the lowest point of the mount and the ground (factory setup)? tractor model isn't important, clearance is clearance.
thanks.
   / ground clearance of 59" blower mount? #2
It would depend a bit on the front tire size (diameter). What do you have now?
i have R4's on it, so i would presume (without going out to check) that they are 25x8.50-14 (according to manual).
my frame rails are 9 1/2" apart but my front mount is 9 9/16" wide. i need to get it machined down to 9 7/16" so i can fit it up in there. until then, i can only estimate that i will have about 10" of ground clearance, which is still at least 4" under the front axle.
i forgot what tractor the mount is for, the blower is technically a 359 that i changed the gears to make a into a 59. whichever tractor used a front mounted pulley to drive it, is what it originally fit.
2011 CIRCLE M 32 FOOT GOOSENECK (A53843)
2011 CIRCLE M 32...
30008 (A53424)
30008 (A53424)
2022 McConnel TRAXX RC28 43in. Remote Controlled Slope Mower (A51691)
2022 McConnel...
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2012 CATERPILLAR 316EL EXCAVATOR (A51406)
2012 CATERPILLAR...
