Gripping well point to pull using 3-point lift
   / Gripping well point to pull using 3-point lift #1
MNBobcat
Platinum Member
I've been told that the 3-point lift on the back of a tractor works great for pulling shallow well points. What is the trick to gripping the pipe? Will a chain wrapped around the shaft of the pipe tighten as its pulled or will it just slip?
I'll be doing this at 6:00am tomorrow. Just looking for ideas on how to grip that pipe.
   / Gripping well point to pull using 3-point lift #2
A chain and a slip hook will grip a pipe well. Wrap several turns of chain around the pipe with the hook on the lower turns. Then place the hook on the last / highest loop. Otherwise the chain will spin the pipe. Useful, if spinning the pipe is what you want.
   / Gripping well point to pull using 3-point lift #3
Put an elbow or a Tee on the top to lift the first section. Then lift at the couplings by wraping with a chain. I used the loader to lift my pipe and didnt have too much problem....not sure with limited lift of the 3 point linkage.
I ended up using the skidsteer. Didn't seem to matter how I wrapped the chain. It gripped. Took less than 5 minutes to pull the point!
2021 CATERPILLAR 306 CR EXCAVATOR (A52709)
2021 CATERPILLAR...
TROYBILT TB685 EC WEEDEATER (A54757)
TROYBILT TB685 EC...
(INOPERABLE) GEHL 8K TELEHANDLER (A58214)
(INOPERABLE) GEHL...
2017 Caterpillar D6T LGP Crawler Tractor Dozer (A55787)
2017 Caterpillar...
MAHINDRA 3650P TRACTOR (A58375)
MAHINDRA 3650P...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
