Gripping well point to pull using 3-point lift
   / Gripping well point to pull using 3-point lift #1
MNBobcat
Platinum Member
I've been told that the 3-point lift on the back of a tractor works great for pulling shallow well points. What is the trick to gripping the pipe? Will a chain wrapped around the shaft of the pipe tighten as its pulled or will it just slip?
I'll be doing this at 6:00am tomorrow. Just looking for ideas on how to grip that pipe.
   / Gripping well point to pull using 3-point lift #2
A chain and a slip hook will grip a pipe well. Wrap several turns of chain around the pipe with the hook on the lower turns. Then place the hook on the last / highest loop. Otherwise the chain will spin the pipe. Useful, if spinning the pipe is what you want.
   / Gripping well point to pull using 3-point lift #3
Put an elbow or a Tee on the top to lift the first section. Then lift at the couplings by wraping with a chain. I used the loader to lift my pipe and didnt have too much problem....not sure with limited lift of the 3 point linkage.
I ended up using the skidsteer. Didn't seem to matter how I wrapped the chain. It gripped. Took less than 5 minutes to pull the point!
1983 INTERNATIONAL S SERIES WATER TRUCK (A57192)
1983 INTERNATIONAL...
2017 Wanco WSDT3-S S/A Towable Radar-Speed Trailer (A55973)
2017 Wanco WSDT3-S...
Deere 335P (A53317)
Deere 335P (A53317)
set of 4 tractor trailer tires Roadforce (A56435)
set of 4 tractor...
New/Unused SD Lanch 12x20 Enclosed Carport (A57454)
New/Unused SD...
2016 PETERBILT 579 DAY CAB ROAD TRACTOR (A54756)
2016 PETERBILT 579...
