Grinds going into reverse
   / Grinds going into reverse #1
seod
Huskee Heavy Duty 14.5hp
I just purchased a used Huskee 14.5hp riding mower with a snow blower attachment on it. Today was the first day of really using it.
It was working fine for a couple hours. After awhile, I couldn't get it into reverse. It would grind, and it just felt like it wasn't going into gear all the way.
Is there an adjustment that can be made? Is is in need of a new belt or spring? Is it something more worrisome, like a new transaxel?
   / Grinds going into reverse #2
:welcome:
Sounds like putting in the clutch is not stopping the transmission from being driven with the belt.
Likely the adjustment of the idler pulley that tightens the belt is not lifting all the way, or also might look for a brake that is supposed to help stop the belt.
The driven pulley and the wheels need to be at a complete stop for the shifting into a gear.
Thanks for the information. I will see what i can do. I am about one day old with lawn tractors, but It looks like I will be learning quickly.
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A51692)
2003 Pierce Tilt...
2016 Ford F-750 14FT Flatbed Truck (A52377)
2016 Ford F-750...
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A51691)
2024 Wanco...
2016 Peterbilt 567 Tri-Axle Dump Truck (A51692)
2016 Peterbilt 567...
96" X 53' FLATBED TRAILER (A52706)
96" X 53' FLATBED...
2011 International WorkStar 7300 Acid Tanker Truck (A52377)
2011 International...
