Grinding noise in mid gear only- B3200
   / Grinding noise in mid gear only- B3200 #1
WarrenPFJr
Catskills, NY
Kubota B3200
Hi all,
I've been running a B3200 since i bought it new in 2009. It has just under 1,000 hours on it. Recently i get this click, click, click noise when in mid gear. It does not happen in high or low gear, just mid gear, all the time, in both 2 and 4 wheel drive. It still runs in mid gear but it makes that annoying sound. I have been using the machine in high or low only to avoid damaging anything and really miss the mid gear. I have also noticed with the HST when i start to push the pedal i get a slight jump before it starts moving. Are these 2 things related? Any thoughts on what my issue is?
Thank you!
   / Grinding noise in mid gear only- B3200 #2
Could be a broken tooth on a gear.
You'll need to take it apart and see what's inside the magical box.
   / Grinding noise in mid gear only- B3200 #3
My 3200 has always had a small ‘surge’ when I first ask it to move, just the nature of the hydraulics. It is amplified in high range.
The clicking could be a number of things, putting the rear of the tractor up on stands and turning the rear wheels by hand (engine off of course) with the L-M-H lever in different positions may help you isolate it.
I got the tractor up and spun the wheels by hand. No noise. Only when I start her up and step on the pedal.
   / Grinding noise in mid gear only- B3200 #5
Did you just spin one wheel? The other wheel would just spin opposite thru the differential. Have a helper spin the other so that both wheels are spinning the same direction so it turns the driveline.
JLG 3248RS Electric Scissor Lift (A56857)
JLG 3248RS...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
UNUSED FUTURE SGB20 20" HYD STUMP GRAB BUCKET (A57193)
UNUSED FUTURE...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A54811)
Miller Trailblazer...
UNUSED WOLVERINE MAD-12-12D HYD AUGER DRIVE & BIT (A57193)
UNUSED WOLVERINE...
UNUSED SDLANCH PORTABLE WOOD CHIPPER (A57193)
UNUSED SDLANCH...
