Grinding noise in mid gear only- B3200
   / Grinding noise in mid gear only- B3200 #1
WarrenPFJr
Catskills, NY
Kubota B3200
Hi all,
I've been running a B3200 since i bought it new in 2009. It has just under 1,000 hours on it. Recently i get this click, click, click noise when in mid gear. It does not happen in high or low gear, just mid gear, all the time, in both 2 and 4 wheel drive. It still runs in mid gear but it makes that annoying sound. I have been using the machine in high or low only to avoid damaging anything and really miss the mid gear. I have also noticed with the HST when i start to push the pedal i get a slight jump before it starts moving. Are these 2 things related? Any thoughts on what my issue is?
Thank you!
   / Grinding noise in mid gear only- B3200 #2
Could be a broken tooth on a gear.
You'll need to take it apart and see what's inside the magical box.
   / Grinding noise in mid gear only- B3200 #3
My 3200 has always had a small ‘surge’ when I first ask it to move, just the nature of the hydraulics. It is amplified in high range.
The clicking could be a number of things, putting the rear of the tractor up on stands and turning the rear wheels by hand (engine off of course) with the L-M-H lever in different positions may help you isolate it.
I got the tractor up and spun the wheels by hand. No noise. Only when I start her up and step on the pedal.
   / Grinding noise in mid gear only- B3200 #5
Did you just spin one wheel? The other wheel would just spin opposite thru the differential. Have a helper spin the other so that both wheels are spinning the same direction so it turns the driveline.
2017 Nissan Versa SV Sedan (A53424)
2017 Nissan Versa...
UNUSED IRANCH SEMI-AUTOMATIC MINI QUICK COUPLER (A57193)
UNUSED IRANCH...
2020 FREIGHTLINER M2 26' BOX TRUCK (A57192)
2020 FREIGHTLINER...
UNUSED FUTURE MINI PALLET FORKS (A57193)
UNUSED FUTURE MINI...
2018 JCB Truss Jib Telescopic Hydraulic Boom (A53421)
2018 JCB Truss Jib...
Adams 5 ton Fertilizer Buggy / Wagon (A53473)
Adams 5 ton...
