Grinding my weld
   / Grinding my weld #1
jel1988
Elliot Lake, ON
2012 Mahindra Max 22, John Deere D120
I'd like to know why my flux core welds grind so easy compared to my mig welds. I like to use mig, the welds are so neet and clean with no spatter. The flux core weld is so easy to grind when it comes to clean up. I'm doing auto body sheet metal, could someone explain this to me?
   / Grinding my weld #2
What name brand, and number of flux core wire are you using?
   / Grinding my weld #3
Crimini Carl! What are you doing up so early, or late? Either way... you shouldn't be. I have an excuse... I'm in Taiwan.
   / Grinding my weld #5
Dang, Carl - there's PILLS fer that :D
I know - I'm ON 'em :( ...Steve
   / Grinding my weld #6
   / Grinding my weld #7
Never said mine were BLUE - you 'fessing UP to somethin Terry??!? ;)
   / Grinding my weld #8
Uncertain what you're getting at, Steve. These are MY blue "pills". I use them regularly and they always bring a smile to my face :)
Terry
   / Grinding my weld #9
I'm pretty sure this is a record. In 7 posts you guys totally derailed this thread.
In Shield Arc's first post he was spot on. So I guess I gotta adjust to 6 posts before derail.
To the OP. I think what you are seeing is the difference in the hardness of the stick weld rod used and the wire weld wire used. No big deal. But a very good time to educate yourself about the differences. If these guys can get off their personal physical limitations and get back to welding. :)
   / Grinding my weld #10
You're right. To the OP. Sorry. I got carried away.
Terry
2014 Jeep Grand Cherokee SUV (A51694)
2014 Jeep Grand...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
(APPROX 15) 2" X 6" X 68" THICK TUBING (A51247)
(APPROX 15) 2" X...
2019 Ford Explorer SUV (A51694)
2019 Ford Explorer...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A51692)
2013 Ford F-150...
(INOP) KUBOTA L2550 TRACTOR (A51247)
(INOP) KUBOTA...
