grill repair
   / grill repair #1
almaryholm
Bronze Member
Lake City,MN
TYM T450 w/ loader...had NH TC30
Noticed the plastic(?) nose of my tractor ( TYM T450) is cracked just above latch ...any ideas how to repair ???
   / grill repair #2
I had to replace one on a T353 HST after poking some brush through it. I believe the grill was less than $30 and arrived in less than a week from my local dealer and took less than 10 minutes to replace. I added a metal guard made out of 1/8" 2X2 angle iron and expanded metal to the factory guard. By cutting the angel iron in two places and bending it I put a curve in the expanded metal which made it quite stiff and rigid. This works well to protect the plastic grill. I'll try to add a picture this weekend.
   / grill repair #3
If the hood itself is cracked try JB Weld compound. It can be sanded down flush and painted. Be sure to drill a hole in the end of the crack as a stress reliever and fill the hole as well.
   / grill repair #4
I have repaired many plastic items including my tractor grill, trailer fender flares and portable gas cans using a hot glue gun.
The trick is to mix some hot glue in with the plastic part being repaired.
Heck I even repaired Cessna plastic wing tips that way.
   / grill repair #5
Drill stop, fiberglass from the rear, fill crack, sand, blend paint
   / grill repair
Talked to dealer today and wants $158.96 for replacement ?!!...guess will be a repair job...funny, there seems to be a double layer of plastic there as not cracked all the way through ( more splintered )...maybe inject some kind of plastic glue and clamp (?) thanks to all...al
   / grill repair #7
Let us know how the repair turns out.
   / grill repair #8
Is it plastic or fiber glass?
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2025 New/Unused Wolverine Brush Cutter (A51573)
2025 New/Unused...
2013 Ford Transit Connect Van (A52377)
2013 Ford Transit...
UNUSED FUTURE 19" EXCAVATOR RAKE (A51248)
UNUSED FUTURE 19"...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
