Gresen Hydraulics valve
/ Gresen Hydraulics valve
Hi
What I want to do is a very simple power unit that will activate a cylinder for a garage press that I'm building. the output of the pump will be fed into the control valve so that it will enable me to push or retreat the cylinder ram. if I got it right - both the existing port and the new unplugged orifice will be connected to the tank.
I will appreciate any comments/advice.
Thanx.
/ Gresen Hydraulics valve #22
For what it's worth, I have 2 Oliver crawlers (OC3, OC46) with Gresen valves and pumps on them. They seem to be good units. As mentioned the company is long gone and availability of replacement parts is pretty much limited to "standard" size components.
2023 Kubota Z252KH-54 Zero Turn Mower (A63689)
2023 Kubota...
2026 Stout TB-76 Tri-Blade Brush Cutter (A64047)
2026 Stout TB-76...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A56858)
Pallet of...
2021 Case 200 Magnum (A64119)
2021 Case 200...
2002 WACKER RD25 ROLLER (A59912)
2002 WACKER RD25...
Mounting Plate Skid Steer Attachment (A61572)
Mounting Plate...
