Loader Gresae fitting for loader lever b2320
/ Gresae fitting for loader lever b2320 #1
ror105
Central PA
2011 Kubota 2320 HSD
My tractor has been greased religiously since new but I have never been able to locate a Zerk for the loader lever.
Anyone have a picture of where the thing is actually located? I know it needs it because it is getting a little stiff with a load in the bucket.
Thanks for any input
/ Gresae fitting for loader lever b2320 #2
Wasn't aware of there being one! Can you find it in the owners manual?
/ Gresae fitting for loader lever b2320 #3
There isn't a grease fitting for the loader control arm. Get a can of white lithium grease, remove the boot at the base of the loader control arm and spray the linkage down.
There is no boot; just 4 small bolts where the bottom of the lever goes to the valve actuator. There doesn't seem to be any place exposed where any lubricant will make any difference.
I will have to investigate some more.
/ Gresae fitting for loader lever b2320 #5
I wouldn't think it would be any difference at the lever if the bucket is loaded or empty. If it is then doesn't sound like lube at lever problem to me.
John, I think part of what you are saying is true. It feels more like the pressure to start to open the valve is greater.
I am just not happy with the little bit of play that is in the lever itself, all the bolts are tight though.
/ Gresae fitting for loader lever b2320 #7
A little penetrating oil would not hurt on the pivots from time to time depending on the amount of use.
/ Gresae fitting for loader lever b2320 #8
Yeah, I squirt oil in there on my B2920 -- there are no grease fittings.
/ Gresae fitting for loader lever b2320 #9
Stay away from the lithium greases. In that environment it'll just attract dirt and make the problem worse. Use some Penetrol 90 on the linkages, it will last longer than wd40 or PB blaster.
I will give the penetrating oil a try.
Thanks!
/ Gresae fitting for loader lever b2320 #11
Thanks!
So are you just going to spray oil where the lever bolts to the control valve>? I would like to do the same to my B2320.
I sprayed around the entire area with Tri-flow. Has Teflon that seems to stick where u want it. Mechanism feels a wee bit better.
When the rain stops I will continue the 230' of French drain and moving the 23 tons of 2B.
I will let you know if it made an improvement.
Rob
The Tri-flow did the trick. The valve functions and releases as well as it did when it was new.
Wish I had tried that a while ago.
Thanks,
Rob
2015 Ford F-450 4x4 Crew Cab Utility Flatbed Truck (A64556)
2015 Ford F-450...
2012 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2012 Caterpillar...
UNVERFERTH HT25 HEADER CART (A63291)
UNVERFERTH HT25...
2018 DODGE RAM 5500 FLAT BED TRUCK (A65643)
2018 DODGE RAM...
2018 Dodge Charger Sedan (A64557)
2018 Dodge Charger...
2013 CATERPILLAR TH514C TELESCOPIC FORKLIFT (A65053)
2013 CATERPILLAR...
