Greetings from TN
   / Greetings from TN #1
jeretp
cunningham, tn
ford 3000
Just joined after I bought a "70's model Ford 3000 diesel. As soon as I began to run it at home it died after 10 mins of use. I let it cool off and it started again. I thought that it might be trash in the fuel. After running it for 10-15 mins each time, it continues to die out, and now the RPM's will rev up just before it dies out. So, I thought I better look for some advice on the internet, and wound up here. I am thinking that I will take it to the mechanic tomorrow, but will be embarrased if its simply a filter. Thanks for giving the opportunity! JP
   / Greetings from TN #2
Welcome aboard. Do you know how long the Diesel Fuel has been in the tank? Is it gelled? Just a thought.
   / Greetings from TN #3
I'd make sure the fuel shut off is opened it is on the right side by the back of the fuel tank (mine leaks thru some fuel even when shut off... counterclockwise is open,
just a thought- don't ask me how I know this can happen, it is also possible this is not your problem but I would check this first..
   / Greetings from TN #4
:salute:Welcome from Ohio
   / Greetings from TN #6
Greetings and Welcome to TractorByNet :tractor:
   / Greetings from TN #7
Welcome!
   / Greetings from TN #8
Welcome from Canada.
   / Greetings from TN
Thanks to all. I Enjoy looking around here and look forward to being a member.
2010 HEIL TOKEN TRAILER (A52472)
2010 HEIL TOKEN...
2014 INTERNATIONAL MA025 26FT NON CDL BOX TRUCK (A52576)
2014 INTERNATIONAL...
2007 International 4300 Box Truck, VIN # 1HTMMAAL27H513415 (A51572)
2007 International...
2022 New Holland T5.120 Tractor with Loader (A51573)
2022 New Holland...
2006 HEIL MC407 (A52472)
2006 HEIL MC407...
2017 TRANSCRAFT TANDEM AXLE DROP DECK TRAILER (A52576)
2017 TRANSCRAFT...
