Green Yanmar Problem
   / Green Yanmar Problem #1
R Barger
Gate City, Va
YANMAR YM336D/W Loader JOHN DEERE 850/ W Loader 2WD&4WD Kubota RTV 900
One of my John Deere 850 tractor has a problem I can't figure out. For the last year or so the coolant won't return to the engine after cool down.
Here is the things I have tried
Checked the hose and the recovery tank for leaks.
Replaced the radiator cap.
Flushed the system with radiator flush.
Replaced the thermostat.
Checked for combustion gas in radiator. [none]
The tractor does not over heat.
It runs perfect.
No smoke or steam from exhaust.
The tractor has slight pressure in the system even if left for days.
I have purchased a head gasket and don't mind to replace it but I would hate to do that and still have the problem.
Tomorrow I am going to back flush the the radiator.
ANY IDEAS?
   / Green Yanmar Problem #2
I’m confused, what’s the problem. Coolant goes into the overflow tank but won’t go back in the radiator later? Have you checked the radiator after this happens and it’s low?
   / Green Yanmar Problem #3
What do you mean by slight pressure after a few days? Is it possible that your hoses are getting soft and ballooning up a bit?
Are you sure that the radiator cap is the correct one? Have you had tested it for pressure/vacuum function?
All the best,
Peter
When the coolant expands it goes to the overflow tank and should be sucked back into the radiator. After a few times of running the over tank overfills if I don't take it out and return it to the radiator.
All the best,
Peter
The slight pressure I am not concerned about. The fact that it hold that pressure shows there is no leak. I have not had it tested. It is a 13lb recommended for the John Deere 850. The old cap had the same problem. I have owned this tractor for several years. 800hrs. I use it to mow about 3 acres weekly. As long as I return the coolant every couple of mowings no problem. I just decided I would try to get to the bottom of the problem before mowing season.
   / Green Yanmar Problem #6
That coolant flowing from the rad into the catch tank is being displaced by air. That air is coming from somewhere, most likely combustion gases. But you said you had the coolant tested for combustion gases, right?
A leakdown test could confirm this.
No I have not had the coolant tested. That was just based on my visual inspection of no bubbles in coolant when running and no funny looking gases or smoke on start up or running. You may be right that's why I have bought the head gasket. Just didn't want to do that if there was something I was missing.
   / Green Yanmar Problem #8
I think you can get test kits from an auto parts store that can tell you if there are combustion gases in your coolant. I would do that before tearing into the engine.
   / Green Yanmar Problem #9
Replace the radiator cap. The vent is plugged or the deflection disc will not spring back.
   / Green Yanmar Problem #10
Make sure the overflow vent is clear. If it isn't, air can't come back in and let the coolant return. I'm a little confused by the statement that there is pressure on the system after shutting down. If there is pressure in the cooling system after it cools off, that would keep the coolant from returning. It should go negative after shut down.
2025 KJ K1230 UNUSED (10) Wire Mesh Netting Rolls (A50860)
2025 KJ K1230...
Equipment Location (A50490)
Equipment Location...
(4) 8 Lug Dual Wheels and Tires (A48837)
(4) 8 Lug Dual...
20ft Shipping Container (A48837)
20ft Shipping...
(1) 12ft Tarter Gate (A48837)
(1) 12ft Tarter...
KUBOTA B26 TRACTOR BACKHOE (A50458)
KUBOTA B26 TRACTOR...
