Green front axle oil?
   / Green front axle oil? #1
Larkspur, Colorado
John Deere 4520 CUT
I added a little too much Hygard to my front axle the other day, so I removed the allen screw in the bell housing to drain some excess. To my surprise, the oil that came out was green (like algae). I'm guessing it has something to do with manufacturing, but I wonder if any of the experts know for sure.
FYI - 2008 JD 4520
   / Green front axle oil? #2
dyed oil helps the mfg's and dealers identify if it still original oil. Was not aware of gear oil being dyed but is not uncommon with hyd oil.
I guess that makes sense, since Hy-gard is JD's hydraulic/transmission oil. Thanks for the info!
   / Green front axle oil? #4
:confused2:I was not aware John Deere had front axle gear oil call HY-GARD? Am I taking a rear seat on this?
The JD web site says Hy-Gard is a hydraulic/transmission oil. Here is a link:
Oil and Lubricants : Hydraulic Oil
It is spec'd for the front axle on my tractor. I don't know if other people use traditional gear oil in their front axles - I'm just following the manual.
   / Green front axle oil? #6
You are correct, Hy-gard for the front axle. Straight from the manual:
Recommended Lubricants
Engine Oil John Deere Plus-50 or TORQ-GARD SUPREME (See SERVICE ENGINE for more information.)
Grease John Deere Multi-Purpose SD Polyurea Grease
John Deere Multi-Purpose HD Lithium Complex Grease
Transmission Oil Low Viscosity HY-GARD (JDM J20D)
Front Axle Oil Low Viscosity HY-GARD (JDM J20D)
Compressor Oil PAG Oil - J.D.
   / Green front axle oil? #8
Correct it has changed over the years. I neglected to look at what tractor was involved from the initial post. Have always used what oil is best for our ambient temp and area.
   / Green front axle oil? #9
For any newer tractor Deere posts them online, which is where I copied that info above from. That was a for a 4000 and 3000 series.
2024 Isuzu NRR 24ft Box Truck (A50323)
2024 Isuzu NRR...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
2025 78in Rock Bucket Skid Steer Attachment (A50322)
2025 78in Rock...
2012 Ford F-450 Altec AT200A 30FT Bucket Truck (A50323)
2012 Ford F-450...
PLEASE VIEW ALL PICTURES!! (A50774)
PLEASE VIEW ALL...
2018 UTILITY VS2DC 53FT REEFER TRAILER (A52141)
2018 UTILITY VS2DC...
