More Corps notes
Whether it is around an obstruction, through dams, or even bedrock, water finds a way. In August 1913 crews worked on sealing up leaks in the bedrock during excavation of the upstream end of the northernmost approach canal. Crews cleaned and sealed the leaking areas probably using a cement-based product like grout, directing the leaking water through a pipe to prevent erosion of the rock and to better manage the incoming water.
The New Lock project included a significant amount of preparatory work to keep groundwater away from the construction site. Contractors installed a grout curtain in a semi-circle around the site to help block the water from leaking into the work area. It isn’t completely watertight, so the groundwater that does seep through is managed using grading and pumps to keep work areas dry enough for construction.
View attachment 3916650View attachment 3916649
