Great Joystick Values
/ Great Joystick Values #1
HayDR
Veteran Member, Approved Advertiser
Johnson City, TN
JD 2040,2240, 2355, 2755, 4055
  • Baileynet.com - 21 gal/m- Joystick Valve- $185 Directional Control Valves 220-905 Detailed Information
Gallons per minute flow is very important. If you system is producing more than the valve's recommended maximum flow rate, it can cause heating problems with the hydraulic fluid.
/ Great Joystick Values #2
Here's a question. Is there a disadvantage to going to the higher rated gpm?
IOW, my pump is about 8gpm. What performance impact, if any, would the 21 gpm model have, if I adapt it to the same size lines on the FEL?
I am considering upgrading the pump to a 12 or 16 gpm (depends on the model), but don't know when (if).
I want more speed on the FEL. Working through some tests and sourcing some parts for upgrading remotes and such at the moment...
- JC
/ Great Joystick Values #3
If you use too big of a valve, you will lose the ability to "feather" the controls that you have with a correctly sized valve.
Aaron Z
- JC
You don't see much of a selection in between 10 gpm and 20 gpm. You will be fine if you go with the 21gpm now. The 21 gpm will have larger ports & the valve will be a little larger. Your system is likely a open-center system, so just get the hydraulic pressure from a power beyond and you will not see any change in your hydraulics.
CUSHMAN REFRESHER GAS GOLF CART (A63276)
CUSHMAN REFRESHER...
2019 Mercedes Sprinter 2500 Cargo Van (A61573)
2019 Mercedes...
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
2025 JMR Stump Bucket Skid Steer Attachment (A61572)
2025 JMR Stump...
2019 Nissan Sentra Sedan (A61574)
2019 Nissan Sentra...
iDrive TDS-2010H...
