Greasing tractors +/-
   / Greasing tractors +/- #1
PA-Kubota
Apollo PA
2008 BX2350
Just curious what type of grease in everyone using? From general to moly based... what's your choice?
BTW have tractor supply close and many big box auto-parts stores.
thanks
   / Greasing tractors +/- #3
I picked this up on Amazon and it's worked for me. I am not a commercial user, 200 hours in 3 1/2 years, but I purchased bulk figuring if I have it I will use it- and that's been the case.
   / Greasing tractors +/- #9
I like the TSC marine & offroad grease.
   / Greasing tractors +/- #10
for the tractor, i don't obsess about the grease type, just frequency of lube.
i've found over the years that grease hardens & can be a bear to break loose.
so time interval is just as important as hrs on the machine between lubes
as a footnote, i've found Lucas marine grease resists hardening over time & moisture conditions
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A56438)
2023 Top Air ATV...
5004 (A55851)
5004 (A55851)
2018 Kubota RTV-X900 4x4 Diesel Utility Cart (A59228)
2018 Kubota...
2014 CATERPILLAR 627K SCRAPER (A60429)
2014 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
