Greasing the CV on a HX15
   / Greasing the CV on a HX15 #11
In all my experience I've only had one CV and BROTHER - it was a real PITA. It was on the front drive shaft of my '69 Ford Bronco. That dam thing would start wobbling and you knew it was time for an overhaul. Finally - I replaced the entire CV joint with one heavy duty U-joint. Not one of Ford's better ideas.
Vehicle driveshaft CV joints are a necessary evil.. :)
   / Greasing the CV on a HX15 #12
Thanks for correcting my oversight because I didn't research the last serial number break on HX15. I'll state eliminating the grease fitting on center section is not one of the best of JD engineers shining moments/thoughts.
2021 BMW 1200RT (A55853)
2021 BMW 1200RT...
2013 JOHN DEERE 27D EXCAVATOR (A52707)
2013 JOHN DEERE...
2005 GMC C8500 16FT Utility Flatbed Truck (A55852)
2005 GMC C8500...
2012 EZ-GO Cart (A55853)
2012 EZ-GO Cart...
10' HYD GRADER BLADE (A57192)
10' HYD GRADER...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A57880)
2018 FREIGHTLINER...
