Greasing the 4510
/ Greasing the 4510 #1
yanmars
Veteran Member
Two questions actually. There is a grease jerk under the rubber floor mat, the front end loader column plate bolts thru the mat such that one cannot lift it far enough to access the jerk. I could use a rubber knife to slit it which would permit enough room to get to the jerk or how do you 4510 owners do this.
The second question is are the zerks sae or have metric threads as I could change it underneath, the jerk is pointed the wrong direction now but that might also work with a straight zerk. Thanks
